Aller au contenu principal
Pebble Time Battery Replacement
Ce dont vous avez besoin
  1. Pebble Time Battery Replacement, Screen Cover: étape 1, image 1 de 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Battery Replacement: étape 2, image 1 de 2 Pebble Time Battery Replacement: étape 2, image 2 de 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Battery Replacement: étape 3, image 1 de 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Battery Replacement: étape 4, image 1 de 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Battery Replacement, Screen: étape 5, image 1 de 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Battery Replacement: étape 6, image 1 de 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Battery Replacement: étape 7, image 1 de 3 Pebble Time Battery Replacement: étape 7, image 2 de 3 Pebble Time Battery Replacement: étape 7, image 3 de 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Battery Replacement, Circuit Board: étape 8, image 1 de 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Battery Replacement: étape 9, image 1 de 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Battery Replacement: étape 10, image 1 de 3 Pebble Time Battery Replacement: étape 10, image 2 de 3 Pebble Time Battery Replacement: étape 10, image 3 de 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Battery Replacement: étape 11, image 1 de 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Battery Replacement: étape 12, image 1 de 2 Pebble Time Battery Replacement: étape 12, image 2 de 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Battery Replacement, Battery: étape 13, image 1 de 1
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Battery Replacement: étape 14, image 1 de 2 Pebble Time Battery Replacement: étape 14, image 2 de 2
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Battery Replacement: étape 15, image 1 de 2 Pebble Time Battery Replacement: étape 15, image 2 de 2
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
32 autres ont terminé cette réparation.
Nicolas Hempe
Membre depuis le 02/15/17
1 444 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 membres
7 tutoriels rédigés
11 commentaires
Where did you purchase the replacement battery?
Dimas Caparros - Réponse
Got mine on Amazon
kwojdak -
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - Réponse
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 35
30 derniers jours : 140
Total : 21,076
