Aller au contenu principal
Pebble Time Circuit Board Replacement
Ce dont vous avez besoin
  1. Pebble Time Circuit Board Replacement, Screen Cover: étape 1, image 1 de 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: étape 2, image 1 de 2 Pebble Time Circuit Board Replacement: étape 2, image 2 de 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: étape 3, image 1 de 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: étape 4, image 1 de 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: étape 5, image 1 de 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: étape 6, image 1 de 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: étape 7, image 1 de 3 Pebble Time Circuit Board Replacement: étape 7, image 2 de 3 Pebble Time Circuit Board Replacement: étape 7, image 3 de 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: étape 8, image 1 de 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: étape 9, image 1 de 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: étape 10, image 1 de 3 Pebble Time Circuit Board Replacement: étape 10, image 2 de 3 Pebble Time Circuit Board Replacement: étape 10, image 3 de 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: étape 11, image 1 de 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: étape 12, image 1 de 2 Pebble Time Circuit Board Replacement: étape 12, image 2 de 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Nicolas Hempe
Membre depuis le 02/15/17
1 444 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 9
Total : 833
