Aller au contenu principal
Pebble Time Screen Replacement
Ce dont vous avez besoin
  1. Pebble Time Screen Replacement, Screen Cover: étape 1, image 1 de 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: étape 2, image 1 de 2 Pebble Time Screen Replacement: étape 2, image 2 de 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: étape 3, image 1 de 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: étape 4, image 1 de 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: étape 5, image 1 de 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: étape 6, image 1 de 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: étape 7, image 1 de 3 Pebble Time Screen Replacement: étape 7, image 2 de 3 Pebble Time Screen Replacement: étape 7, image 3 de 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
Saud Al-Malki
Membre depuis le 02/19/17
110 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 membres
7 tutoriels rédigés
3 commentaires
Where can I buy the display replacement?
ulises - Réponse
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - Réponse
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 12
Total : 3,180
