Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Pelonis Four Slice Toaster Oven Disassembly
Ce dont vous avez besoin
    1. Pelonis Four Slice Toaster Oven Disassembly, Pelonis Four Slice Toaster Oven: étape 1, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly, Pelonis Four Slice Toaster Oven: étape 1, image 2 de 2
      • Remove the two 12 mm screws at the bottom of the toaster using a Phillips #1 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Pelonis Four Slice Toaster Oven Disassembly: étape 2, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 2, image 2 de 2
      • Remove the four 8 mm screws from the inside edge of the toaster using a Phillips #0 screwdriver.
      Demander à FixBot
    3. Pelonis Four Slice Toaster Oven Disassembly: étape 3, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 3, image 2 de 2
      • Remove the four 12 mm screws at the back of the toaster using a Phillips #1 screwdriver.
      Demander à FixBot
    4. Pelonis Four Slice Toaster Oven Disassembly: étape 4, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 4, image 2 de 2
      • Remove the rubber backings from the legs of the toaster by pulling them out with your hands.
      Demander à FixBot
    5. Pelonis Four Slice Toaster Oven Disassembly: étape 5, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 5, image 2 de 2
      • Remove the 12 mm screw from the inside of the leg using a Phillips #0 screwdriver.
      • This allows us to remove the leg stands from the toaster.
      Demander à FixBot
    6. Pelonis Four Slice Toaster Oven Disassembly: étape 6, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 6, image 2 de 2
      • Remove the back to access the inner mechanism; you can also remove the black covering at this step.
      Demander à FixBot
    7. Pelonis Four Slice Toaster Oven Disassembly: étape 7, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 7, image 2 de 2
      • The LED light can be removed for replacement.
      Demander à FixBot
    8. Pelonis Four Slice Toaster Oven Disassembly: étape 8, image 1 de 3 Pelonis Four Slice Toaster Oven Disassembly: étape 8, image 2 de 3 Pelonis Four Slice Toaster Oven Disassembly: étape 8, image 3 de 3
      • Remove the 12 mm screws surrounding the temperature switch using a Phillips #1 screwdriver.
      Demander à FixBot
    9. Pelonis Four Slice Toaster Oven Disassembly: étape 9, image 1 de 2 Pelonis Four Slice Toaster Oven Disassembly: étape 9, image 2 de 2
      • The temperature switch is now free for replacement.
      Demander à FixBot
    10. Pelonis Four Slice Toaster Oven Disassembly: étape 10, image 1 de 3 Pelonis Four Slice Toaster Oven Disassembly: étape 10, image 2 de 3 Pelonis Four Slice Toaster Oven Disassembly: étape 10, image 3 de 3
      • With all other components out of the way, you have access to the wires connecting to the heating elements as well as the heating elements themselves, which you can now replace.
      Demander à FixBot
Pièces jointes
Anya Buyea
Membre depuis le 09/14/25
231 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 27
Total : 156
