Aller au contenu principal
Penguin FZ-8 28” Tower Fan Blade Replacement
Ce dont vous avez besoin
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: étape 1, image 1 de 1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 2, image 1 de 3 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 2, image 2 de 3 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 2, image 3 de 3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 3, image 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 3, image 2 de 2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 4, image 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 4, image 2 de 2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 5, image 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 5, image 2 de 2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 6, image 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 6, image 2 de 2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 7, image 1 de 1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 8, image 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: étape 8, image 2 de 2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: étape 9, image 1 de 1
    • Remove the fan blade from the device and clean it off before reassembling your device.
Ethan
Membre depuis le 03/22/21
169 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G4, Riel Spring 2021 Membre de l'équipe UMass Dartmouth, Team S2-G4, Riel Spring 2021
UMASSD-RIEL-S21S2G4
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 53
Total : 961
