Aller au contenu principal
Pentax LX ISO Resistor Cleaning
Ce dont vous avez besoin
  1. Pentax LX ISO Resistor Cleaning, Remove rewind knob: étape 1, image 1 de 2 Pentax LX ISO Resistor Cleaning, Remove rewind knob: étape 1, image 2 de 2
    • Place a thin tool in the rewind fork and unscrew the topside knob.
    • Remove the washer under the rewind knob.
  2. Pentax LX ISO Resistor Cleaning, Remove exposure compensation dial: étape 2, image 1 de 3 Pentax LX ISO Resistor Cleaning, Remove exposure compensation dial: étape 2, image 2 de 3 Pentax LX ISO Resistor Cleaning, Remove exposure compensation dial: étape 2, image 3 de 3
    • Remove three #000 5.5 mm screws.
    • Remove exposure compensation dial assembly.
    • Remove washer.
    • Remove rubber seal.
  3. Pentax LX ISO Resistor Cleaning, Remove rewind side top cover: étape 3, image 1 de 2 Pentax LX ISO Resistor Cleaning, Remove rewind side top cover: étape 3, image 2 de 2
    • Remove one #00 X mm screw.
    • Remove one #00 2.5 mm screw.
  4. Pentax LX ISO Resistor Cleaning, Clean ISO resistor: étape 4, image 1 de 2 Pentax LX ISO Resistor Cleaning, Clean ISO resistor: étape 4, image 2 de 2
    • The resistor assembly is crimped or pressed together and further disassembly is not possible.
    • Use a cotton bud and isopropyl alcohol to clean the surface of the resistive element.
    • Spray a plastic safe contact cleaner in the area of the feeler contacts.
    • Rotate the dial back and forth several times.
    • Check the resistance between the purple wire and ground. It should range from 7.5 kΩ to 200 kΩ with no dead spots.
  5. Pentax LX ISO Resistor Cleaning, Replace ISO resistor: étape 5, image 1 de 1
    • If the resistor still doesn't function properly after cleaning, remove it a replace it with a new part.
    • Unsolder one purple wire.
    • Unsolder one green wire.
    • Unsolder two brown wires.
    • Remove three #00 screws.
Sam Gustafson
Membre depuis le 09/01/22
7 682 Réputation
42 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 39
Total : 72
