Aller au contenu principal
Pentax LX Top Cover (Wind Side) Removal
Ce dont vous avez besoin
  1. Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: étape 1, image 1 de 3 Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: étape 1, image 2 de 3 Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: étape 1, image 3 de 3
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
  2. Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: étape 2, image 1 de 3 Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: étape 2, image 2 de 3 Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: étape 2, image 3 de 3
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
  3. Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: étape 3, image 1 de 3 Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: étape 3, image 2 de 3 Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: étape 3, image 3 de 3
    • Remove one #00 2.5 mm screw.
    • Remove one #00 X mm screw.
    • Lift off top cover.
Sam Gustafson
Membre depuis le 09/01/22
7 682 Réputation
42 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 30
Total : 192
