Introduction
Use this guide to remove and replace a damaged battery cover on the Pentax Optio WG-2.
Ce dont vous avez besoin
Étape 1 Back Case
Attention : les étapes 1 à 6 sont issues d'un tutoriel marqué comme en cours.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Lift the cover as you normally would if replacing battery.
Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
