Aller au contenu principal
Pentax Optio WG-3 GPS Lens Assembly Replacement
Ce dont vous avez besoin
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: étape 1, image 1 de 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: étape 2, image 1 de 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: étape 3, image 1 de 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: étape 4, image 1 de 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: étape 5, image 1 de 1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: étape 6, image 1 de 1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: étape 7, image 1 de 1
    • Gently slide the lens piece to the right, remove the tape and take it out.
Garrett Rose
Membre depuis le 03/31/22
373 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-1, Harley Spring 2022 Membre de l'équipe IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 194
