Aller au contenu principal
Pentax Optio WG-3 GPS Motherboard Replacement
Ce dont vous avez besoin
  1. Pentax Optio WG-3 GPS Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Motherboard Replacement: étape 2, image 1 de 1
    • Flip over the camera so the bottom is facing up.
    • Use the Phillips PH0005 again to remove one more 5mm screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Motherboard Replacement: étape 3, image 1 de 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Motherboard Replacement: étape 4, image 1 de 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Motherboard Replacement: étape 5, image 1 de 1
    • There is a large silver sticker on top of the motherboard, gently remove it off of the motherboard.
  6. Pentax Optio WG-3 GPS Motherboard Replacement: étape 6, image 1 de 1
    • Gently use the spudger set to lift open the clamps that are holding the orange ribbons down.
    • Pull out the ribbons and remove the motherboard from the body of the camera.
  7. Pentax Optio WG-3 GPS Motherboard Replacement: étape 7, image 1 de 1
    • Remove the battery on the back of the motherboard.
  8. Pentax Optio WG-3 GPS Motherboard Replacement: étape 8, image 1 de 1
    • Unscrew and remove one 2 mm Phillips #00 screw to remove the flash component on the top of the circuitry.
  9. Pentax Optio WG-3 GPS Motherboard Replacement: étape 9, image 1 de 1
    • Remove three 5 mm Phillips #000 screws from the left side of the motherboard.
  10. Pentax Optio WG-3 GPS Motherboard Replacement: étape 10, image 1 de 1
    • Remove two ribbon cables from the small circuit.
    • Remove the ribbon cable that holds the sensor to the motherboard.
  11. Pentax Optio WG-3 GPS Motherboard Replacement: étape 11, image 1 de 1
    • The sensor is ready to be pulled out, carefully remove the sensor.
  12. Pentax Optio WG-3 GPS Motherboard Replacement: étape 12, image 1 de 1
    • Unscrew and remove three 5 mm screws from the front panel of the battery compartment.
  13. Pentax Optio WG-3 GPS Motherboard Replacement: étape 13, image 1 de 1
    • Pull the black panel away from the front panel.
  14. Pentax Optio WG-3 GPS Motherboard Replacement: étape 14, image 1 de 1
    • At the top of the circuit board there are three soldered dots that need to be unsoldered to remove the back of the battery component from the motherboard.
    • The motherboard can now be pulled and replaced.
Garrett Rose
Membre depuis le 03/31/22
373 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-1, Harley Spring 2022 Membre de l'équipe IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 237
