Introduction
If your Pentax Optio WG-3 GPS camera will not power on or function, refer to this guide to replace the motherboard. When handling the silver circuitry cover in step 6 use extreme caution to not bend the cover too far because the cover is extremely fragile.
In step 10, you will need to desolder the connecting pins to the motherboard. Before starting, be sure the device is fully powered off and be sure to remove the battery.
Ce dont vous avez besoin
Turn over the camera so the screen is facing up.
Remove the four 5 mm Phillips #000 screws that secure the outer cover.
