Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
PREREQUISITE GUIDE ONLY.
Pièces
Aucune pièce spécifiée.
  1. Remove the 4 mm black screw on the bottom right corner of the mother board.
    • Remove the 4 mm black screw on the bottom right corner of the mother board.
    • The black screw may be hard to remove. Use the tweezers if necessary.
  2. With the tweezers, carefully peel back the copper ribbon that was underneath the black screw.
    • With the tweezers, carefully peel back the copper ribbon that was underneath the black screw.
  3. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  4. Remove the 2.5 mm silver screw from the upper left corner of the motherboard.
    • Remove the 2.5 mm silver screw from the upper left corner of the motherboard.
  5. Press down on the metal plate and gently lift the motherboard up from left to right. Be cautious when lifting the motherboard since there is a copper ribbon and two wires attaching the motherboard to the flash unit.
    • Press down on the metal plate and gently lift the motherboard up from left to right.
    • Be cautious when lifting the motherboard since there is a copper ribbon and two wires attaching the motherboard to the flash unit.
    • Reorient the camera so you are looking at the top edge with the metal plate on the right.
Derek
Membre depuis le 21/01/2011
746 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-13, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
5 membres
9 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 234
