Introduction
If the back cover of the Pentax PZ-10 won't lock in place, the spring that holds the door in place may need to be replaced.
Ce dont vous avez besoin
With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
Pull off the bottom casing to remove.
With the screws removed, the bottom casing should come off very easily by pulling on the casing.
Press down on the locking switch on the side panel facing you.
Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
