Ce dont vous avez besoin
Loosen three grub screws. Do not remove them from the frame counter cover.
Lift off frame counter cover.
Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
Remove the frame counter dial.
Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
Remove the dial seat.
Remove three 2.3 mm flat head screws.
Use a pick to rotate the retaining washer until the lobed sections are free.
Lift off the advance lever.
Remove the plastic shim washer.
Remove one 2.8 mm pin head screw.
Remove the shutter speed dial.
Remove the ISO dial.
Remove the internal spring.
Remove the dial housing.
The hole in the dial housing needs to go over the tab on the speed resistor.
The tab on the ISO dial needs to mate with the hole in the dial housing.
It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
Place a thin, sturdy tool in the spindle fork.
Unscrew the rewind knob.
Use a spanner wrench to unscrew the retaining nut.
Remove the film reminder
Remove the spring washer.
Remove the friction plate.
Remove one 5.3 mm flat head screw and attached spring.
Remove one 9.1 mm flat head screw.
Remove the shutter ready indicator.
Remove two 3.4 mm flat head screws from the wind stopper.
Remove the wind spring from the retention post.
Remove the wind driver.
Move the ratchet teeth outward such that they won't engage with the main wind gear but are still held in place by the bias springs.
Install the wind driver.
Hook the wind spring on its retention post.
Turn the wind driver counter-clockwise until the wind spring drops inside the corner of the camera chassis.
Install the wind stopper plate.
Push the ratchet teeth in to engage them with the main wind gear. The bias springs should look like this when properly installed.
Hold the cap washer in place while unhooking the main spring.
Remove the cap washer.
Remove the main spring.
Remove the ratchet pawl.
Remove the shim washer.
Remove the counter advance gear and lever.
2 autres ont terminé cette réparation.
