Aller au contenu principal
Pentax ZX-5n Flash Pivot Replacement
Ce dont vous avez besoin
  1. Pentax ZX-5n Flash Pivot Replacement, Remove back cover: étape 1, image 1 de 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Flash Pivot Replacement, Remove bottom cover: étape 2, image 1 de 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Flash Pivot Replacement, Remove left front cover: étape 3, image 1 de 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Flash Pivot Replacement, Remove front cover: étape 4, image 1 de 2 Pentax ZX-5n Flash Pivot Replacement, Remove front cover: étape 4, image 2 de 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Flash Pivot Replacement, Remove right front cover: étape 5, image 1 de 1
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Flash Pivot Replacement, Remove eye cup: étape 6, image 1 de 1
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: étape 7, image 1 de 3 Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: étape 7, image 2 de 3 Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: étape 7, image 3 de 3
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Flash Pivot Replacement, Lift top cover: étape 8, image 1 de 1
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Flash Pivot Replacement, Discharge flash capacitors: étape 9, image 1 de 1
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Flash Pivot Replacement, Release top cover: étape 10, image 1 de 3 Pentax ZX-5n Flash Pivot Replacement, Release top cover: étape 10, image 2 de 3 Pentax ZX-5n Flash Pivot Replacement, Release top cover: étape 10, image 3 de 3
    • De-solder the green, blue, brown and black wires from the flash PCB.
    • De-solder the black wire.
    • Pull the black wire out until it is completely free from the body of the camera.
  11. Pentax ZX-5n Flash Pivot Replacement, Desolder flex cable: étape 11, image 1 de 1
    • Desolder the flex cable connecting the top plate to the camera body.
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
  12. Pentax ZX-5n Flash Pivot Replacement, Pop up the flash: étape 12, image 1 de 1
    • Push the release button to pop up the flash.
  13. Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: étape 13, image 1 de 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: étape 13, image 2 de 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: étape 13, image 3 de 3
    • Remove two 2.9mm #000 screws.
    • Remove two 4.4 mm #00 screws.
    • Close the flash and lift off the top cover.
  14. Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: étape 14, image 1 de 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: étape 14, image 2 de 3 Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: étape 14, image 3 de 3
    • Remove the latch spring.
    • Remove the latch plate. The flash will try to pop up when it is removed.
  15. Pentax ZX-5n Flash Pivot Replacement, Remove pop up spring: étape 15, image 1 de 1
    • Release the spring arm from the post.
    • Remove the pop up spring.
  16. Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: étape 16, image 1 de 2 Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: étape 16, image 2 de 2
    • Remove one 3.3 mm #00 screw.
    • Hold the pivot in place while unscrewing.
  17. Pentax ZX-5n Flash Pivot Replacement, Install screw: étape 17, image 1 de 1
    • When using the 3D printed part supplied on the device page, install a 4mm #00 screw in the end of the pivot to hold it together.
2 autres ont terminé cette réparation.
Sam Gustafson
Membre depuis le 09/01/22
3 350 Réputation
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 27
Total : 362
