Introduction
One common failure of the ZX-5n is the pop up flash. The pivot holding the spring can break relieving the tension on the spring. When this happens, the flash will no longer pop up to its proper position. It may be possible to repair the existing part with epoxy but you can also replace it with a donor part from another camera or with a 3D printed part. A model for the 3D printed part can be found in the Documents section of the Pentax ZX-5n page.
Ce dont vous avez besoin
Push down on the screw to depress the spring loaded hinge and release the door.
Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
Remove one 7.3 mm #00 screw.
Remove the remote trigger cover.
Remove two 5.3 mm #00 screws by the eyepiece.
Remove one 6.8 mm #00 screw in the battery compartment.
Remove one 7.0 mm #00 screw near the take up spool.
Lift the cover so it is just free of the body. It is still attached by several wires.
Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
De-solder the green, blue, brown and black wires from the flash PCB.
De-solder the black wire.
Pull the black wire out until it is completely free from the body of the camera.
Desolder the flex cable connecting the top plate to the camera body.
Remove two 2.9mm #000 screws.
Remove two 4.4 mm #00 screws.
Close the flash and lift off the top cover.
Remove one 3.4 mm #00 screw.
Remove the latch spring.
Remove the latch plate. The flash will try to pop up when it is removed.
Release the spring arm from the post.
Remove the pop up spring.
When using the 3D printed part supplied on the device page, install a 4mm #00 screw in the end of the pivot to hold it together.
2 autres ont terminé cette réparation.
