Aller au contenu principal
Performance Tool W50042 Trigger Switch Replacement
Ce dont vous avez besoin
  1. Performance Tool W50042 Trigger Switch Replacement, Trigger Switch: étape 1, image 1 de 1
    • Remove the battery by pressing the yellow tabs on both sides, then pull the battery out.
  2. Performance Tool W50042 Trigger Switch Replacement: étape 2, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 2, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 2, image 3 de 3
    • Remove the nine 1/2 inch Phillips head screws.
  3. Performance Tool W50042 Trigger Switch Replacement: étape 3, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 3, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 3, image 3 de 3
    • Use a T-25 hex bit to remove four 1'1/2 hex head screws.
  4. Performance Tool W50042 Trigger Switch Replacement: étape 4, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 4, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 4, image 3 de 3
    • Remove the shaft cover.
  5. Performance Tool W50042 Trigger Switch Replacement: étape 5, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 5, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 5, image 3 de 3
    • Remove the case.
  6. Performance Tool W50042 Trigger Switch Replacement: étape 6, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 6, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 6, image 3 de 3
    • Lift the trigger switch to remove the direction switch.
  7. Performance Tool W50042 Trigger Switch Replacement: étape 7, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 7, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 7, image 3 de 3
    • Unscrew the red wire from the motor (Phillips head screw 1/4 inch).
  8. Performance Tool W50042 Trigger Switch Replacement: étape 8, image 1 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 8, image 2 de 3 Performance Tool W50042 Trigger Switch Replacement: étape 8, image 3 de 3
    • Pick up the motor and remove the black wire (Phillips head screw 1/4 inch).
David
Membre depuis le 09/19/22
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 384
