Aller au contenu principal
Petmate 29027 Fountain Lid and Pump Replacement
Ce dont vous avez besoin
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: étape 1, image 1 de 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: étape 1, image 2 de 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: étape 1, image 3 de 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: étape 2, image 1 de 3 Petmate 29027 Fountain Lid and Pump Replacement: étape 2, image 2 de 3 Petmate 29027 Fountain Lid and Pump Replacement: étape 2, image 3 de 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: étape 3, image 1 de 2 Petmate 29027 Fountain Lid and Pump Replacement: étape 3, image 2 de 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: étape 4, image 1 de 3 Petmate 29027 Fountain Lid and Pump Replacement: étape 4, image 2 de 3 Petmate 29027 Fountain Lid and Pump Replacement: étape 4, image 3 de 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: étape 5, image 1 de 2 Petmate 29027 Fountain Lid and Pump Replacement: étape 5, image 2 de 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: étape 6, image 1 de 2 Petmate 29027 Fountain Lid and Pump Replacement: étape 6, image 2 de 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Ligne d'arrivée
Shidie Ren
Membre depuis le 05/11/20
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G22, O'Regan Summer 2020 Membre de l'équipe York University, Team S1-G22, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G22
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 28
Total : 510
