Aller au contenu principal
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
Ce dont vous avez besoin
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: étape 1, image 1 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: étape 1, image 2 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: étape 1, image 3 de 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 2, image 1 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 2, image 2 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 2, image 3 de 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 3, image 1 de 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 4, image 1 de 1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 5, image 1 de 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 5, image 2 de 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 6, image 1 de 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 6, image 2 de 2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 7, image 1 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 7, image 2 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: étape 7, image 3 de 3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
Ashley Kim
Membre depuis le 10/08/18
187 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S13-G7, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 316
