Introduction
Use this guide to replace the battery for your SmartFeeder to get your device up and running again. This guide is also a prerequisite to access and replace the motherboard and charging assembly.
Pièces
Aucune pièce nécessaire.
  1. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Turn the bowl tray side down by using both hands.
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
Kristin Villanueva
Membre depuis le 08/10/2018
370 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G7, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 16
Total : 72
