Aller au contenu principal
Philips BiPAP S/T Air Filter Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Vidéo d'introduction
  1. Philips BiPAP S/T Air Filter Replacement, Air Filter: étape 1, image 1 de 1
    • Disconnect the device from the power source to stop airflow.
    • To avoid electrical shock, always unplugged the power cord from the wall outlet before cleaning the device.
  2. Philips BiPAP S/T Air Filter Replacement: étape 2, image 1 de 2 Philips BiPAP S/T Air Filter Replacement: étape 2, image 2 de 2
    • Remove the filter from the enclosure by gently squeezing the filter in the center and pulling it away from the device.
    • Examine the filter for cleanliness and quality.
    • If the foam filter is torn, replace it. (Only Philips Respironics-supplied filters should be used as replacement filters.)
    • A dirty inlet filter may cause high operating temperatures that may affect device performance. Regularly examine the inlet filter.
  3. Philips BiPAP S/T Air Filter Replacement: étape 4, image 1 de 1
    • Wash the gray foam filter in warm water with a mild detergent.
    • Rinse thoroughly to remove all detergent residue.
    • Allow the filter to air dry completely before reinstalling it.
    • Never install a wet filter into the device. You must ensure sufficient drying time.
  4. Philips BiPAP S/T Air Filter Replacement: étape 5, image 1 de 1
    • Reinstall the filter.
    • To install, insert gray foam filter into the filter area.
    • A properly installed, undamaged filter is required for proper operation.
Sophia James
Membre depuis le 04/07/20
193 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G3, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
3 membres
3 tutoriels rédigés
2 commentaires
In India corona virus control in a earlier situation and now its spread in many countries again '''bipap machines''' are necessary for many peoples in this situation but you have to be careful from your side as well btw thanks for informative article.
mers - Réponse
Why is there a gray blue material coming out on the output filter. It has been doing for over two years. Is it killing me. My bi pa was recalled over a year ago, when are they going to replace it ?
EDward Stone - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 1,302
