Aller au contenu principal
Philips BiPAP S/T Blower Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
Vidéo d'introduction
  1. Philips BiPAP S/T Blower  Replacement, Blower: étape 1, image 1 de 1
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: étape 2, image 1 de 1
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: étape 3, image 1 de 1
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: étape 4, image 1 de 1
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: étape 7, image 1 de 1
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
2 autres ont terminé cette réparation.
Benjamin LaVigna
Membre depuis le 04/07/20
243 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G3, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
3 membres
3 tutoriels rédigés
Un commentaire
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 32
Total : 2,760
