Aller au contenu principal
Philips DC320 37 Bottom Button Circuit Board Replacement
Ce dont vous avez besoin
  1. Philips DC320 37 Bottom Button Circuit Board Replacement, Docking entertainment system: étape 1, image 1 de 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Bottom Button Circuit Board Replacement: étape 2, image 1 de 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Bottom Button Circuit Board Replacement: étape 3, image 1 de 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Bottom Button Circuit Board Replacement: étape 4, image 1 de 3 Philips DC320 37 Bottom Button Circuit Board Replacement: étape 4, image 2 de 3 Philips DC320 37 Bottom Button Circuit Board Replacement: étape 4, image 3 de 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Bottom Button Circuit Board Replacement, Bottom Button Circuit Board: étape 5, image 1 de 1
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
  6. Philips DC320 37 Bottom Button Circuit Board Replacement: étape 6, image 1 de 1
    • Pull the board out from the dock
Greg Lane
Membre depuis le 04/16/13
39 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 3-48, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 membres
6 tutoriels rédigés
Un commentaire
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 884
