Aller au contenu principal
Philips DC320 37 Headphone or Power Jack Replacement
Ce dont vous avez besoin
  1. Philips DC320 37 Headphone or Power Jack Replacement, Docking entertainment system: étape 1, image 1 de 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Headphone or Power Jack Replacement: étape 2, image 1 de 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Headphone or Power Jack Replacement: étape 3, image 1 de 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Headphone or Power Jack Replacement: étape 4, image 1 de 3 Philips DC320 37 Headphone or Power Jack Replacement: étape 4, image 2 de 3 Philips DC320 37 Headphone or Power Jack Replacement: étape 4, image 3 de 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Headphone or Power Jack Replacement, Headphone or Power Jack: étape 5, image 1 de 1
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  6. Philips DC320 37 Headphone or Power Jack Replacement: étape 6, image 1 de 1
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  7. Philips DC320 37 Headphone or Power Jack Replacement: étape 7, image 1 de 1
    • Separate the white suport bracket from the headphone/power electronics board.
Graham Rolph
Membre depuis le 04/18/13
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-48, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,255
