Aller au contenu principal
Philips DVP5992-F7 HDMI port Replacement
Ce dont vous avez besoin
  1. Philips DVP5992-F7 HDMI port Replacement, HDMI port: étape 1, image 1 de 3 Philips DVP5992-F7 HDMI port Replacement, HDMI port: étape 1, image 2 de 3 Philips DVP5992-F7 HDMI port Replacement, HDMI port: étape 1, image 3 de 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 HDMI port Replacement: étape 2, image 1 de 2 Philips DVP5992-F7 HDMI port Replacement: étape 2, image 2 de 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 HDMI port Replacement: étape 3, image 1 de 3 Philips DVP5992-F7 HDMI port Replacement: étape 3, image 2 de 3 Philips DVP5992-F7 HDMI port Replacement: étape 3, image 3 de 3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 HDMI port Replacement: étape 4, image 1 de 1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 HDMI port Replacement: étape 5, image 1 de 1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 HDMI port Replacement: étape 6, image 1 de 1
    • Remove the motherboard from the DVD player.
Nathan Sarti
Membre depuis le 08/31/18
274 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 9
Total : 258
