Aller au contenu principal
Philips DVP5992-F7 Power Cord Replacement
Ce dont vous avez besoin
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: étape 1, image 1 de 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: étape 1, image 2 de 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: étape 1, image 3 de 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: étape 2, image 1 de 2 Philips DVP5992-F7 Power Cord Replacement: étape 2, image 2 de 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: étape 3, image 1 de 3 Philips DVP5992-F7 Power Cord Replacement: étape 3, image 2 de 3 Philips DVP5992-F7 Power Cord Replacement: étape 3, image 3 de 3
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
Dyllon Phuong
Membre depuis le 08/31/18
540 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 8
Total : 387
