Aller au contenu principal
Philips DVP642 Power Supply Replacement
Ce dont vous avez besoin
  1. Philips DVP642 Power Supply Replacement, Top Panel: étape 1, image 1 de 2 Philips DVP642 Power Supply Replacement, Top Panel: étape 1, image 2 de 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: étape 2, image 1 de 2 Philips DVP642 Power Supply Replacement: étape 2, image 2 de 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: étape 3, image 1 de 2 Philips DVP642 Power Supply Replacement, Power Supply: étape 3, image 2 de 2
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: étape 4, image 1 de 1
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: étape 5, image 1 de 2 Philips DVP642 Power Supply Replacement: étape 5, image 2 de 2
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: étape 6, image 1 de 2 Philips DVP642 Power Supply Replacement: étape 6, image 2 de 2
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: étape 7, image 1 de 3 Philips DVP642 Power Supply Replacement: étape 7, image 2 de 3 Philips DVP642 Power Supply Replacement: étape 7, image 3 de 3
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: étape 8, image 1 de 2 Philips DVP642 Power Supply Replacement: étape 8, image 2 de 2
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
7 autres ont terminé cette réparation.
Toby Goldsteinholm
Membre depuis le 10/09/11
360 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 21-20, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 50
Total : 13,347
