Aller au contenu principal
Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Philips Emerson CoughAssist CA Series Disassembly: étape 1, image 1 de 1
    • First, remove the two 16mm pan head screws (1) directly under the front panel of the ventilator. (Page 3).
    • Next, remove the two 16mm flat head screws (3) from the back panel of the ventilator. (Page 3).
    • Lift off the top cover (2) of the device. (Page 3).
  2. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 4, image 1 de 2 Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 4, image 2 de 2
    • Now remove the "Inhale flow" control knob (4) and "Inhale pressure" knob (4), by loosening the setscrew on each before pulling off. If you have a CM model, carefully remove the Manual Control Lever (3) by prying it off with the screwdriver. (Page 3).
  3. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 5, image 1 de 1
    • Unscrew the three 12.7mm plastite screws ( 2) holding the panel assembly to the lower housing. A long Phillips screwdriver is very helpful for access to the three screws. (Page 3)
    • The front control panel (5) should now be loose. Carefully slide it forwards to remove. (Page 4).
  4. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Valve Actuator Motor: étape 7, image 1 de 3 Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Valve Actuator Motor: étape 7, image 2 de 3 Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Valve Actuator Motor: étape 7, image 3 de 3
    • Position the ventilator so the pressure gauge is facing right to your right.
    • Follow the Preliminary Disassembly Guide to remove the top cover and the front panel.
  5. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 8, image 1 de 2 Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 8, image 2 de 2
    • Remove the two 12.7mm plastite screws (10) as shown, and remove the Power Filter (9). (Page 7)
    • Remove all screws holding the Bracket (6) to the Valve Assembly (12). (Page 7)
    • Remove the two 12.7mm plastite screws above and the one screw beneath the Actuator Motor (9). (Page 7)
    • Take out the Actuator Motor (9) while it is still attached to the Bracket (6). (Page 7)
  6. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 9, image 1 de 1
    • If you notice other parts are damaged or faulty, replace them. These parts include the torsion spring (1), cable chain (3), larger sprocket (4), or the spacer (2). (Page 7).
    • The small sprocket on the motor is not designed to be removed from the shaft, so make sure you are replacing the large sprocket.
  7. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 10, image 1 de 2 Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: étape 10, image 2 de 2
    • Disconnect the two motor terminals from the motor capacitor (7). (Page 7).
    • Remove the 4 6.4mm binding head screws holding the motor to the bracket. (Page 7).
    • Remove the motor. (Page 7)
To reassemble your device, follow these instructions in reverse order. After reassembly, check that the cable chain(3) is tensioned properly. This means that the two sides of the chain can be pinched together almost half way, but not able to touch. If you need more detail or looking for more information on this repair, please refer to the Service Guide attached, page 7.
Pièces jointes
Zachary Stednitz
Membre depuis le 04/07/20
292 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S11-G18, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S11-G18, Paton Spring 2020
CPSU-PATON-S20S11G18
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 14
Total : 291
