Aller au contenu principal
Philips HD9252 Latch Button Replacement
Ce dont vous avez besoin
  1. Philips HD9252 Latch Button Replacement, Tray: étape 1, image 1 de 1
    • Remove the tray from the air fryer by pressing the latch button in, and pulling the handle away.
  2. Philips HD9252 Latch Button Replacement: étape 2, image 1 de 1
    • Pull the tray out of the basket.
  3. Philips HD9252 Latch Button Replacement, Latch Button: étape 3, image 1 de 2 Philips HD9252 Latch Button Replacement, Latch Button: étape 3, image 2 de 2
    • Remove the two 14.8 mm screws placed in the top of the latch using a Phillips #00 screwdriver.
    • Remove the two 14.8 mm screws placed on the bottom of the latch using a Phillips #00 screwdriver.
  4. Philips HD9252 Latch Button Replacement: étape 4, image 1 de 1
    • Remove the four 14.8 mm screws placed on front of the latch button using a Phillips #00 screwdriver.
  5. Philips HD9252 Latch Button Replacement: étape 5, image 1 de 1
    • Pry off the back panel of the handle.
  6. Philips HD9252 Latch Button Replacement: étape 6, image 1 de 2 Philips HD9252 Latch Button Replacement: étape 6, image 2 de 2
    • Push the spring down with a nylon spudger so that it is underneath the button.
    • Slide the spring out of the back of the handle.
  7. Philips HD9252 Latch Button Replacement: étape 7, image 1 de 1
    • Remove the front of the latch from the handle.
  8. Philips HD9252 Latch Button Replacement: étape 8, image 1 de 1
    • Remove the button through the back of the handle.
Rolando_Gonzalez
Membre depuis le 02/14/24
233 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 3-1, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 3-1, Sneed Spring 2024
UM-SNEED-S24S3G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 25
Total : 82
