Aller au contenu principal
Philips Norelco BeardTrimmer 3100 Handle Replacement
Ce dont vous avez besoin
  1. Philips Norelco BeardTrimmer 3100 Handle Replacement, Front and Back Panels: étape 1, image 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 2, image 1 de 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 2, image 2 de 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 3, image 1 de 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 3, image 2 de 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 4, image 1 de 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 4, image 2 de 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 4, image 3 de 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 5, image 1 de 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 5, image 2 de 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 5, image 3 de 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 6, image 1 de 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 6, image 2 de 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 7, image 1 de 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 8, image 1 de 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: étape 8, image 2 de 2
2 autres ont terminé cette réparation.
filmon gebregergis
Membre depuis le 09/03/15
143 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 15-2, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 5,735
