Aller au contenu principal
Philips Norelco BeardTrimmer 3100 Power Switch Replacement
Ce dont vous avez besoin
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: étape 1, image 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 2, image 1 de 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 2, image 2 de 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 3, image 1 de 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 3, image 2 de 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 4, image 1 de 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 4, image 2 de 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 4, image 3 de 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 5, image 1 de 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 5, image 2 de 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 5, image 3 de 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 6, image 1 de 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 6, image 2 de 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 7, image 1 de 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 8, image 1 de 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 8, image 2 de 2
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: étape 9, image 1 de 1
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 10, image 1 de 1
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 11, image 1 de 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 11, image 2 de 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 11, image 3 de 3
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: étape 12, image 1 de 1
    • Remove the power switch from the front panel once the white plastic frame is removed.
Tamara Titus
Membre depuis le 09/03/15
157 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 15-2, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 17
Total : 6,086
