Aller au contenu principal
Philips Norelco MultiGroom 3100 Motor Replacement
Ce dont vous avez besoin
  1. Philips Norelco MultiGroom 3100 Motor Replacement, Power Button: étape 1, image 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Motor Replacement: étape 2, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement: étape 2, image 2 de 2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Motor Replacement: étape 3, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement: étape 3, image 2 de 2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Motor Replacement: étape 4, image 1 de 1
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Motor Replacement, Casing: étape 5, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement, Casing: étape 5, image 2 de 2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Motor Replacement: étape 6, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement: étape 6, image 2 de 2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Motor Replacement, Motor: étape 7, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement, Motor: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to pull out the inner power button.
  8. Philips Norelco MultiGroom 3100 Motor Replacement: étape 8, image 1 de 1
    • Use the plastic opening tool to separate the clip on the right side of the inner housing.
  9. Philips Norelco MultiGroom 3100 Motor Replacement: étape 9, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement: étape 9, image 2 de 2
    • Push the inner housing up and to the right to separate the left clip from the battery casing.
    • Push the inner housing upwards to separate it from the battery casing.
  10. Philips Norelco MultiGroom 3100 Motor Replacement: étape 10, image 1 de 2 Philips Norelco MultiGroom 3100 Motor Replacement: étape 10, image 2 de 2
    • Use the tweezers to hold the wire steady as you unsolder the blue wire from the power switch.
    • Use the tweezers to remove the power switch.
    • For help with soldering check out the iFixit Soldering Technique Guide.
  11. Philips Norelco MultiGroom 3100 Motor Replacement: étape 11, image 1 de 3 Philips Norelco MultiGroom 3100 Motor Replacement: étape 11, image 2 de 3 Philips Norelco MultiGroom 3100 Motor Replacement: étape 11, image 3 de 3
    • Pull up on the motor to remove it from the battery casing.
    • Use the tweezers to hold the black wire steady while unsoldering it from the base of the battery.
    • Using the tweezers, pull on the black wire to remove it from the base of the battery.
4 autres ont terminé cette réparation.
ahaharevolution
Membre depuis le 10/04/15
759 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-1, Leahy Fall 2015
USFT-LEAHY-F15S1G1
2 membres
3 tutoriels rédigés
4 commentaires
¿Me puedes ayudar con algo?
Johan Avendaño - Réponse
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Nina Lovekrist - Réponse
Where can I get the motor with copper shaft?
amal.hardik - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 45
Total : 4,735
