Aller au contenu principal
Philips Norelco Shaver 2100 Battery Replacement
Ce dont vous avez besoin
  1. Philips Norelco Shaver 2100 Battery Replacement, Casing: étape 1, image 1 de 1
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Battery Replacement: étape 2, image 1 de 2 Philips Norelco Shaver 2100 Battery Replacement: étape 2, image 2 de 2
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Battery Replacement: étape 3, image 1 de 1
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Battery Replacement: étape 4, image 1 de 2 Philips Norelco Shaver 2100 Battery Replacement: étape 4, image 2 de 2
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Battery Replacement: étape 5, image 1 de 3 Philips Norelco Shaver 2100 Battery Replacement: étape 5, image 2 de 3 Philips Norelco Shaver 2100 Battery Replacement: étape 5, image 3 de 3
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Battery Replacement: étape 6, image 1 de 3 Philips Norelco Shaver 2100 Battery Replacement: étape 6, image 2 de 3 Philips Norelco Shaver 2100 Battery Replacement: étape 6, image 3 de 3
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
  7. Philips Norelco Shaver 2100 Battery Replacement, Battery: étape 7, image 1 de 3 Philips Norelco Shaver 2100 Battery Replacement, Battery: étape 7, image 2 de 3 Philips Norelco Shaver 2100 Battery Replacement, Battery: étape 7, image 3 de 3
    • Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
  8. Philips Norelco Shaver 2100 Battery Replacement: étape 8, image 1 de 1
    • Located directly behind the circuit board, remove the battery from the device.
11 autres ont terminé cette réparation.
Équipe
USF Tampa, Team S1-G4, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G4, Thompson Fall 2017
USFT-THOMPSON-F17S1G4
3 membres
5 tutoriels rédigés
14 commentaires
To remove the battery you have to actually desolder both ends from the chip.
AGUSTIN CABRA - Réponse
What are the dimensions/specs of the battery?
Haley Pearse - Réponse
regular AA rechargeable batteries will not work and can be a fire hazard.
steven - Réponse
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
Don - Réponse
I have a similar Norelco razor and replaced the battery. I can’t believe the stupid company didn’t mark the battery polarity on the board!
I think this is the first time I have ever seen a company not mark polarity.
Laz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 38
30 derniers jours : 139
Total : 21,077
