Aller au contenu principal
Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement, Oxygen Inlet Filter: étape 1, image 1 de 1
    • Turn off the device.
    • On/Off switch located on the Front Panel as seen in Figure 8-2 (from the Operator Manual).
    • Disconnect from AC power.
  2. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: étape 3, image 1 de 1
    • Disconnect the oxygen hose.
    • Oxygen hose is connected to the Inlet Connector (section 14 of Figure 5-1, diagram from Operator Manual).
  3. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: étape 4, image 1 de 2 Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: étape 4, image 2 de 2
    • Unscrew the water trap bowl (page 10-5 in Service Manual).
    • Located on the back panel of the ventilator (section 15 of Figure 5-1 from Operator Manual).
  4. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: étape 5, image 1 de 1
    • Separate the filter element from the black plastic retainer (page 10-5 of Service Manual).
    • Attach new filter element to the black plastic retainer (page 10-5 of Service Manual).
    • Reconnect the oxygen hose.
    • According to page 2-2 of the Operators Manual, care in the routing of the oxygen inlet hose should be exercised to ensure it is not exposed to mechanisms that could cause damage by cutting or heating/melting.
  • Reconnect to AC Power.
  • To reassemble your device, follow these instructions in reverse order.
Grace Gius
Membre depuis le 05/04/20
505 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G4, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G4, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G4
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 254
