Aller au contenu principal
Philips Respironics V200 Esprit Power Supply Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Philips Respironics V200 Esprit Power Supply Replacement, Power Supply: étape 1, image 1 de 1
    • Remove the power supply shroud (Instructions found in Chapter 10.8 on page 10-21 of the Service Manual).
  2. Philips Respironics V200 Esprit Power Supply Replacement: étape 2, image 1 de 1
    • Loosen the screws on power supply connector TB1 (page 10-22 of Service Manual).
    • Disconnect the following wires:
    • Brown (terminal 1)
    • Blue (terminal 2)
    • Green (Terminal 4)
  3. Philips Respironics V200 Esprit Power Supply Replacement: étape 3, image 1 de 1
    • Loosen the screws on power supply connector TB2 (page 10-22 of Service Manual).
    • Red (Terminal 1)
    • Black (Terminal 4)
    • Caution! Do not remove the black ground wire from TB3 Terminal 3.
  4. Philips Respironics V200 Esprit Power Supply Replacement: étape 4, image 1 de 1
    • Loosen the screws on the power supply connector TB3 (page 10-22 in Service Manual).
    • Red (Terminal 1)
    • Black (Terminal 2)
    • Caution! Do not remove the black ground wire from TB3 Terminal 2.
    • Using a 4-mm hex driver, remove the eight M5 x 12 screws that secure the power supply to the top enclosure (page 10-22 in Service Manual),
  5. Philips Respironics V200 Esprit Power Supply Replacement: étape 6, image 1 de 1
    • For this step, lift the power supply as needed (page 10-22 of Service Manual).
    • Disconnect cables from connectors J1, J2, and J3.
  6. Philips Respironics V200 Esprit Power Supply Replacement: étape 7, image 1 de 1
    • Lift the power supply from the top enclosure (page 10-22 of Service Manual).
    • You must install the MMI PCB before installing the power supply. Information on how to do this can be found in Chapter 10.12 on page 10-26 of the Service Manual.
    • When installing the power supply, make sure no cables are routed underneath the power supply.
  7. Philips Respironics V200 Esprit Power Supply Replacement: étape 8, image 1 de 1
    • Reinstalling the power supply (page 10-24 of Service Manual):
    • Reinstall the eight screws that hold the power supply to the top enclosure.
    • Do not tighten the screws until all are installed.
    • Connect the following cables to the power supply (page 10-24 of Service Manual):
    • Cable PSU J1 to connector J1
    • Cable PSU J2 to connector J2
    • Cable PSU J3 to connector J3
    • Install the following wires to the power supply (page 10-24 of Service Manual):
    • Red and black wires (PSU TB3) to connector TB3
    • Red and black wires (PSU TB2) to connector TB2
    • Blue, green, and brown wires from the AC mains panel to connector TB1
    • When installing, push the wires completely into the connectors.
    • No wires should be visible after being tightened at the terminal block.
  8. Philips Respironics V200 Esprit Power Supply Replacement: étape 11, image 1 de 1
    • Reinstall the power supply shroud (Instructions found in Chapter 10.8 on page 10-21 of the Service Manual).
    • Make sure the red and black wires from TB3 rest inside the shroud slots.
    • Make sure the shroud does nor pinch any cables.
    • All cable assemblies and wires must be routed between the shroud and the top enclosure wall.
    • The black ground wire reattaches to the shroud with the longer screw (near connector TB2).
Ligne d'arrivée
Grace Gius
Membre depuis le 05/04/20
505 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G4, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G4, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G4
5 membres
5 tutoriels rédigés
Un commentaire
Is this available?
Shashikumar G - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 10
Total : 301
