Introduction
The Touchscreen is the main command function of the Ventilator and is the prime source to navigate the different functions of the Ventilator.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Philips's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Philips.
Re-Calibration of the touchscreen is discussed in:
- chapter 5.3 “Diagnostic Mode and Troubleshooting - Touch Screen Calibration” of service manual
- Appendix F “Diagnostic mode - Touchscreen calibration” of user manual
Assembly of touchscreen is discussed in:
- chapter 7.32 “Component Removal/Installation - Front Bezel, Touch Screen” of service manual
From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
If the calibration is not successful, have the ventilator serviced.
Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
Remove the switch PCBA.
Remove the screw that attaches the cable clamp to the LCD tray.
Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
Remove the touch screen from the front bezel.
