Introduction
The capacitor is the cylindrical shaped protruding object located on the circuit board. This guide will detail the instructions on how to replace the capacitor.
Ce dont vous avez besoin
Remove the back cover by sliding it off.
Remove the 3 AAA batteries.
Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
Slowly pull the circuit board out of the device
NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
Remove the light plug from the circuit board.
Locate the capacitor and carefully slide it out of the circuit board.
NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
Reassemble the speaker.
