Introduction
The circuit board is the large, flat, green rectangle in the middle of the device. This guide will detail the steps in how to replace the circuit board.
Ce dont vous avez besoin
Remove the back cover by sliding it off.
Remove the 3 AAA batteries.
Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
Remove the damaged circuit board from the device.
Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
Remove the light plug from the circuit board.
Reassemble the device.
2 autres ont terminé cette réparation.
2 commentaires
Is that one of those cheap pam amps that run from 5v?
