Aller au contenu principal
Philips Satinelle Gear Replacement
Ce dont vous avez besoin
  1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: étape 1, image 1 de 2 Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: étape 1, image 2 de 2
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Gear Replacement: étape 2, image 1 de 3 Philips Satinelle Gear Replacement: étape 2, image 2 de 3 Philips Satinelle Gear Replacement: étape 2, image 3 de 3
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Gear Replacement: étape 3, image 1 de 1
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Gear Replacement: étape 4, image 1 de 3 Philips Satinelle Gear Replacement: étape 4, image 2 de 3 Philips Satinelle Gear Replacement: étape 4, image 3 de 3
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Gear Replacement: étape 5, image 1 de 3 Philips Satinelle Gear Replacement: étape 5, image 2 de 3 Philips Satinelle Gear Replacement: étape 5, image 3 de 3
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Gear Replacement: étape 6, image 1 de 3 Philips Satinelle Gear Replacement: étape 6, image 2 de 3 Philips Satinelle Gear Replacement: étape 6, image 3 de 3
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Gear Replacement: étape 7, image 1 de 3 Philips Satinelle Gear Replacement: étape 7, image 2 de 3 Philips Satinelle Gear Replacement: étape 7, image 3 de 3
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Gear Replacement, Gear Replacement: étape 8, image 1 de 1
    • Replace the gear and re-insert the pin.
    • Ensure that pin is protruding slightly, it should not be flush.
Nathan Christian
Membre depuis le 11/11/17
505 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 membres
4 tutoriels rédigés
2 commentaires
What size pinion is used in it? Kindly help.
Wilkis James - Réponse
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
Emilio Hernandez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 22
Total : 1,293
