1. Unplug the device and remove the purple guard.
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip.
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
    • The left side will swing down.
    • Remove the Tweezers.
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
    • Use a spudger to pry the gear housing unit from the base.
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
    • Replace Metal Roller Tracks on both sides of the Tweezer Head.
Nathan Christian
Membre depuis le 11/11/2017
440 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 57
