Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If you need to replace the metal rolling tracks of your Philips Satinelle, use this guide.
  1. Unplug the device and remove the purple guard. Remove the head by pressing the right side of the head (with the device facing away from you).
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip. Be careful not to lose the clip. It will likely fly off when it releases. Be careful not to lose the clip. It will likely fly off when it releases.
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. The left side will swing down.
    • The left side will swing down.
    • Remove the Tweezers.
  4. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  5. Remove the plastic component that swings down. Use fingernails to lift clips from stubs. Use fingernails to lift clips from stubs.
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  6. Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head. Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head. Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  7. Use a spudger to pry the gear housing unit from the base. Use a spudger to pry the gear housing unit from the base. Use a spudger to pry the gear housing unit from the base.
    • Use a spudger to pry the gear housing unit from the base.
  8. Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin. Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin. Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  9. Replace Metal Roller Tracks on both sides of the Tweezer Head.
    • Replace Metal Roller Tracks on both sides of the Tweezer Head.
Nathan Christian
Membre depuis le 11/11/2017
455 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 195
