Aller au contenu principal
Philips Satinelle Plastic Cover Replacement
Ce dont vous avez besoin
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: étape 1, image 1 de 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: étape 1, image 2 de 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: étape 1, image 3 de 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: étape 2, image 1 de 2 Philips Satinelle Plastic Cover Replacement: étape 2, image 2 de 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: étape 3, image 1 de 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
Madeline Casalino
Membre depuis le 10/08/18
313 Réputation
3 tutoriels rédigés
Équipe
Marist, Team S1-G1, Chaterdon Fall 2018 Membre de l'équipe Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 8
Total : 539
