Unplug the device and remove the purple guard.
  • Unplug the device and remove the purple guard.
  • Remove the head by pressing the right side of the head (with the device facing away from you).
  • You will hear a 'click' and the head will become dislodged from the body of the device.
Ajouter un commentaire
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip.
  • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
  • Be careful not to lose the clip. It will likely fly off when it releases.
  • The left side will swing down.
  • Remove the Tweezers.
  • Remove the plastic component that swings down.
  • Use fingernails to lift clips from stubs.
  • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  • Use a spudger to pry the gear housing unit from the base.
  • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  • Replace Tweezer Head.
  • Ensure that the gear is inserted into the gear box end of the head.
  • When closing the head, make sure that the Tweezer is seated correctly. To check this, the tweezers should spin fairly easily with the finger.
Nathan Christian
Membre depuis le 11/11/2017
425 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S5-G5, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 101
