Aller au contenu principal
Philips Sonicare DiamondClean Circuit Board Replacement
Ce dont vous avez besoin
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: étape 1, image 1 de 2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: étape 1, image 2 de 2
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: étape 2, image 1 de 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: étape 3, image 1 de 3 Philips Sonicare DiamondClean Circuit Board Replacement: étape 3, image 2 de 3 Philips Sonicare DiamondClean Circuit Board Replacement: étape 3, image 3 de 3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: étape 4, image 1 de 1
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: étape 5, image 1 de 1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: étape 6, image 1 de 1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 62
Total : 2,715
