Aller au contenu principal
Philips Sonicare DiamondClean Motor Replacement
Ce dont vous avez besoin
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: étape 1, image 1 de 2 Philips Sonicare DiamondClean Motor Replacement, Motor: étape 1, image 2 de 2
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: étape 2, image 1 de 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: étape 3, image 1 de 2 Philips Sonicare DiamondClean Motor Replacement: étape 3, image 2 de 2
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: étape 4, image 1 de 2 Philips Sonicare DiamondClean Motor Replacement: étape 4, image 2 de 2
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: étape 5, image 1 de 1
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: étape 6, image 1 de 1
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: étape 7, image 1 de 1
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: étape 8, image 1 de 2 Philips Sonicare DiamondClean Motor Replacement: étape 8, image 2 de 2
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: étape 9, image 1 de 2 Philips Sonicare DiamondClean Motor Replacement: étape 9, image 2 de 2
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: étape 10, image 1 de 1
    • Remove the motor and replace.
2 commentaires
Do you have a part number for the motor?
Suraj Daryapurkar - Réponse
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 37
30 derniers jours : 137
Total : 6,191
