Aller au contenu principal
Philips Sonicare FlexCare UV Light Bulb Replacement
  1. Philips Sonicare FlexCare UV Light Bulb Replacement, UV Light Bulb: étape 1, image 1 de 1
    • Before initiating the process, ensure that the sanitizer is not plugged into an outlet. Swing the door open to expose the interior of the sanitizing device.
  2. Philips Sonicare FlexCare UV Light Bulb Replacement: étape 2, image 1 de 1
    • Grip the sides of the plastic cover that is shielding the circuitry. Pull the cover outward to remove it from the sanitizer.
  3. Philips Sonicare FlexCare UV Light Bulb Replacement: étape 3, image 1 de 2 Philips Sonicare FlexCare UV Light Bulb Replacement: étape 3, image 2 de 2
    • Squeeze the sides of the guard that is placed over the UV light bulb. Pull the piece outward to remove it.
  4. Philips Sonicare FlexCare UV Light Bulb Replacement: étape 4, image 1 de 2 Philips Sonicare FlexCare UV Light Bulb Replacement: étape 4, image 2 de 2
    • Before holding the light bulb, ensure that it is not warm due to previous use. Once that is confirmed, take a hold of the light bulb by the threaded surface and rotate it while pulling it outward. Have a compatible UV bulb to replace the old one.
6 autres ont terminé cette réparation.
Tasha Panattoni
Membre depuis le 04/14/15
792 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-6, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 membres
23 tutoriels rédigés
6 commentaires de tutoriel
I’ve had mines less than a year. The uv lamp makes a “whizz sound for a second and then stops. No noise. No light. Does the bulb needs to be replaced ? Is it normal for it to die in 9 mths?
Uroos ali - Réponse
I’ve had my unit for over 7 years, I was getting ready to replace it. Thanks so much, I’m not a handy person and I’m really pleased to see that I could fix this problem with your helpful advice!
roleplay1 - Réponse
Just changed the bulb and it still does not work :( :( :(
nicoleproulx47 - Réponse
Do UV bulbs need changing on a yearly basis or are they still good if giving out light?
jujsf - Réponse
I've had mine for close to 10 years I'm just now having to change my UV bulb
Christopher Hurtle - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 55
Total : 12,232
