Aller au contenu principal
Philips TAS7505 Battery Replacement
Ce dont vous avez besoin
  1. Philips TAS7505 Battery Replacement, Battery: étape 1, image 1 de 3 Philips TAS7505 Battery Replacement, Battery: étape 1, image 2 de 3 Philips TAS7505 Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove the rubber dampener from the bottom of the speaker using your opening tool.
    • However, this will make it harder to replace the rubber dampener, and it may not stick. It is not necessary to the speaker's function.
  2. Philips TAS7505 Battery Replacement: étape 2, image 1 de 3 Philips TAS7505 Battery Replacement: étape 2, image 2 de 3 Philips TAS7505 Battery Replacement: étape 2, image 3 de 3
    • Remove the four Phillips #0 screws attached to the cover and remove with the opening tool.
  3. Philips TAS7505 Battery Replacement: étape 3, image 1 de 2 Philips TAS7505 Battery Replacement: étape 3, image 2 de 2
    • Remove all Phillips #0 screws to remove the final layers to open the inside.
  4. Philips TAS7505 Battery Replacement: étape 4, image 1 de 2 Philips TAS7505 Battery Replacement: étape 4, image 2 de 2
    • Remove the battery from the motherboard.
    • The cable that connects the battery to the speaker is attached to small pins. You can use your hands to wiggle the battery out.
  5. Philips TAS7505 Battery Replacement: étape 5, image 1 de 2 Philips TAS7505 Battery Replacement: étape 5, image 2 de 2
    • After removing the battery, insert the replacement battery.
Frederick Jimenez
Membre depuis le 09/26/22
277 Réputation
2 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 34
Total : 543
