Aller au contenu principal
Philips TAS7505 Speaker Replacement
Ce dont vous avez besoin
  1. Philips TAS7505 Speaker Replacement, Speaker: étape 1, image 1 de 3 Philips TAS7505 Speaker Replacement, Speaker: étape 1, image 2 de 3 Philips TAS7505 Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Using the opening tool, remove the rubber padding from the bottom of the speaker.
    • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
  2. Philips TAS7505 Speaker Replacement: étape 2, image 1 de 3 Philips TAS7505 Speaker Replacement: étape 2, image 2 de 3 Philips TAS7505 Speaker Replacement: étape 2, image 3 de 3
    • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
    • Use the same opening tool from the previous step to remove the plastic plate.
  3. Philips TAS7505 Speaker Replacement: étape 3, image 1 de 3 Philips TAS7505 Speaker Replacement: étape 3, image 2 de 3 Philips TAS7505 Speaker Replacement: étape 3, image 3 de 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Speaker Replacement: étape 4, image 1 de 3 Philips TAS7505 Speaker Replacement: étape 4, image 2 de 3 Philips TAS7505 Speaker Replacement: étape 4, image 3 de 3
    • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
    • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
  5. Philips TAS7505 Speaker Replacement: étape 5, image 1 de 3 Philips TAS7505 Speaker Replacement: étape 5, image 2 de 3 Philips TAS7505 Speaker Replacement: étape 5, image 3 de 3
    • Find the rubber flap that covers the USB-A and USB-C port
    • Pull on the rubber flap, it should come out whole as shown in the second image
    • Once taken out the rubber flap, pull the interior of the speaker
  6. Philips TAS7505 Speaker Replacement: étape 6, image 1 de 2 Philips TAS7505 Speaker Replacement: étape 6, image 2 de 2
    • Once you have the speaker body out, unscrew the four screws holding the speaker down
    • Use Philips screwdriver head #0
  7. Philips TAS7505 Speaker Replacement: étape 7, image 1 de 1
    • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
    • See the motherboard repair guide for more in-depth instructions on this part
  8. Philips TAS7505 Speaker Replacement: étape 8, image 1 de 3 Philips TAS7505 Speaker Replacement: étape 8, image 2 de 3 Philips TAS7505 Speaker Replacement: étape 8, image 3 de 3
    • The speaker will look like this if you have followed the steps correctly
Frederick Jimenez
Membre depuis le 09/26/22
277 Réputation
2 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 30
Total : 851
