Aller au contenu principal
Philips TAS7505 USB-A & USB-C port Replacement
Ce dont vous avez besoin
  1. Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: étape 1, image 1 de 2 Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: étape 1, image 2 de 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 USB-A & USB-C port Replacement: étape 2, image 1 de 3 Philips TAS7505 USB-A & USB-C port Replacement: étape 2, image 2 de 3 Philips TAS7505 USB-A & USB-C port Replacement: étape 2, image 3 de 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 USB-A & USB-C port Replacement: étape 3, image 1 de 3 Philips TAS7505 USB-A & USB-C port Replacement: étape 3, image 2 de 3 Philips TAS7505 USB-A & USB-C port Replacement: étape 3, image 3 de 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 USB-A & USB-C port Replacement: étape 4, image 1 de 3 Philips TAS7505 USB-A & USB-C port Replacement: étape 4, image 2 de 3 Philips TAS7505 USB-A & USB-C port Replacement: étape 4, image 3 de 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 USB-A & USB-C port Replacement: étape 5, image 1 de 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 USB-A & USB-C port Replacement, USB-A & USB-C port: étape 6, image 1 de 1
    • Use the Phillips #0 Screwdriver to remove all 6 screws.
  7. Philips TAS7505 USB-A & USB-C port Replacement: étape 7, image 1 de 1
    • Before pulling the USB port box out, disconnected the power connector from the motherboard.
    • Carefully pull out the USB port box
Yamilena Hernandez
Membre depuis le 09/26/22
135 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 144
