Introduction
In this guide you will use a #1 and #1.5 screwdriver to remove various screws and components. Once you have gained access to the speaker you will have to use creative techniques to remove speaker.
Ce dont vous avez besoin
Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
Identify the two Phillips (Length-5/16" Head-1/8") screws holding the speaker in place and remove them.
After all extra components are out of the way, you will need to remove the adhesive holding the speaker using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar). Once that is completed, replace the broken speaker with the new, functional speaker.
Upon removing the plastic bracket, you will need to remove the adhesive using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar) that is holding the speaker in place. Once that is completed, replace the broken speaker with a new, functional speaker.
